Hello @All,
I'm working on serveral scheduled tasks and business rules.
I have a custom database connection (MySQL) with username and password in the script/scheduled task.
My question:
Is this possible that I define a systemwide variable for the username and password, so I can reuse it in the script/scheduled tasks?
Has anyone a hint about that?
Arne
by (360 points)
Hello Arne,
Unfortunately, there is no possibility to have a global variable that will be used in multiple scripts.
Hi there, we have some custom commands that need the enter-pssession with -sshtransport which is only available in PWSH7. Is it supported to install powershell7 right on the adaxes server? Kind regards, Constantin
asked Mar 3, 2022 by Constey (190 points)
Hello We are currently using IBM Identity Manger, but it's very expensive solution and really an overkill compared to our needs. Wonder if any have experience replacing a "real" IDM system with Adaxes ?
asked Jun 11, 2015 by Boxx.dk (2.6k points)
asked Jan 17, 2023 by stevehalvorson (110 points)
I am trying to work out a method to create Drop-Down lists to select printers and printer properties. Using PowerShell I can extract a list of printers and printer properties to either ... or CSV file for my drop-down lists. Any ideas on how to do this? Thanks
asked Sep 17, 2019 by Fixxer (40 points)
Hello, We have a problem with the way Adaxes detects % as variables in all PowerShell scripts. We are configuring a HTML email template for all out going emails from the system ... this is a start of a variable. Is there anyway around this? Regards, ice-dog
asked Feb 22, 2019 by ice-dog (170 points)
3,348 questions
545,060 users
