I'm trying to update mailNickname to cas_{ but nothing seems to work. This is my completed script of everything working but changing the mailNickname at the end of the code. Any ideas would be helpful. Thanks
Here is the basic code
# Update User mailNickname NOT WORKING
$cas = "cas_{"
$Context.SetModifiedPropertyValue("mailNickname", $cas)
#$Context.SetModifiedPropertyValue("mailNickname", "cas_{") Wont work also
Here is the completed script.
Import-Module Adaxes
$upnSuffix = "YYYYY.com" # TODO: modify me
function IsUserNameUnique($username)
   $user = Get-AdmUser $username -erroraction silentlycontinue
   return $user -eq $Null
# Get the username
$username = $Context.GetModifiedPropertyValue("samAccountName")
# Check if the username is unique
if (IsUserNameUnique($username))
# If the username is not unique, generate a unique one
$firstName = $Context.GetModifiedPropertyValue("givenName")
$lastName = $Context.GetModifiedPropertyValue("sn")
$uniqueUsername = $Null
if (($firstName -ne $NULL) -and ($lastName -ne $NULL))
    $username = $lastName.Substring(0, 7)
    $Context.LogMessage($username, "Information")
    $Context.LogMessage($lastName, "Information")
    foreach ($char in $firstName.ToCharArray())
        $username = "$username$char"
            $uniqueUsername = $username
            break
if ($uniqueUsername -eq $NULL)
    for ($i = 1; $True; $i++)
        $uniqueUsername = $username + $i;
        if (IsUserNameUnique($uniqueUsername))
            break
# Update User Logon Name (pre-Windows 2000)
$Context.SetModifiedPropertyValue("samAccountName", $uniqueUsername)
$Context.SetModifiedPropertyValue("userPrincipalName", "$uniqueUsername@$upnSuffix")
$Context.LogMessage("The username has been changed to " + $uniqueUsername `
    + ".", "Information")
$cas = "cas_{"
by (420 points)
That's strange. Do you get any errors and/or warnings?
I do not get any errors when the account is built.
by (420 points)
I got it working. I pulled it from the other script and set up adaxes to run the change command after the username has been checked.
Thanks for the update!
When I enable a scheduled task, instead of running at the scheduled time they all run imeadiately. This is not good behavior as changes are written in a way to reflect the ... is being enabled. I am hoping there is a powershell command to stop this behavoir.
asked Jul 10, 2023 by mightycabal (1.0k points)
We are implementing the new version of LAPS built into Windows 10 with KB5025221. I've added the attribute to the Management Views for Computers, but the password is not being ... we have not loaded it into AD and plan to use the latest implementation of LAPS.
asked Jul 12, 2023 by jshields (20 points)
I'm trying to modify mailbox settings to add additional email addresses to a user after creation. This is a hybrid on-prem and Exchange Online with E5 licenses. Everything works up ... to a different OU during the process so I know the user exists. Any ideas?
asked Mar 6, 2023 by Michael Long (70 points)
3,326 questions
7,723 comments
544,675 users
