I am trying to run a PS script and get the following error (snipped):-
"Cannot convert the "130978519257589890" value of type "Softerra.Adaxes.Adsi.AdsLargeInteger" to type "System.Double"
How do I convert this attribute?
I have tried converting like this (and get the same convert error):-
[System.Double]$Value = $Value
Note: I'm not sure if I can instead fetch the attribute value as a System.Double type by tweaking the ADSI Get command:-
$Value = $targetPC.Get($targetProperty)
by (1.6k points)
To convert a value of type Softerra.Adaxes.Adsi.AdsLargeInteger to type System.Double, you can use the following method:
$Value = [System.Double]::Parse($targetPC.Get($targetProperty))
By the way, is your ultimate goal to represent the property as a System.Date structure? If so, you can use the following method:
$propertyValue = $targetPC.Get($targetProperty)
$datetime = [DateTime]::FromFiletime([Int64]::Parse($propertyValue))
Many thanks!
Yes, you're right we're trying to pull and display an epoch time. I was using the following PS command, but will also try your solution!
$TimeStamp      = [timezone]::CurrentTimeZone.ToLocalTime(([datetime]'1/1/1970').AddSeconds($Value))
Hello, I'm wondering why i'am missing Domain-DNS object type. Running latest version 3.16.21906.0 (64 bit). I'm running with domain admin & adaxes service ... -custom-commands-scheduled-reports-and-scheduled-tasks-s394.htm This is my Object Type list:
asked Apr 1 by PeterS (40 points)
I’m looking for a way to take a unique number from Adaxes and use part of it to create an employee ID for the AD attribute field.
asked Dec 25, 2023 by cewilson (140 points)
Hello, how can I define the standard Group type when I want to create a group in adaxes. If I use the button Create Group on the home screen the standard group type ... "Universal" and "Security" selected as standard. How can I configure this? Thanks, Fabian
asked Feb 28, 2023 by fabian.p (150 points)
asked Jan 17, 2023 by stevehalvorson (110 points)
Dear Support We have a business rule in the old Adaxes 2017 that was working: Before adding a universal security group to a global security group, the group type of the ... adding a universal group to a global group? <br> Our action: Best regards Johann
asked Nov 30, 2021 by Johann Ihnen (170 points)
3,350 questions
545,067 users
