Is it possible to have a business unit that contains the expired accounts?
by (420 points)
There is no such possibility.
As a workaround, you can use the built-in Expired User Accounts report.
Hi there, I've a business unit containing all shared mailboxes. In The Admin Console the filter is okay and the affected objects show the accounts: But when ... provide a list of all shared mailboxes (which are disabled aswell). Kind regards Constantin
asked May 28, 2021 by Constey (190 points)
I'm trying to make a BU to capture user accounts that haven't logged in to AD in 60 days. I have a BU with the following Query, but it isn't working (&(sAMAccountType=805306368 ... with a script. I just thought it would be easy to do with a BU Thx! --Joel
asked Nov 4, 2015 by ashmite (470 points)
I'm trying to setup SelfService group management. We have multiple Forests. Because of the Forests we can't add users from a different forest to the ManagedBy. We can add a local ... end up getting all the groups a user is a memberof or nothing at all. :)
asked Jun 23, 2021 by ComputerHabit (790 points)
Hi, I'm trying to create a web console only for sending SMS using adaxes 2018.2. The SMS-users that are going to use the console should only be able to view users, not edit ... which removes a lot of OUs that the users should not see or be able to browse to.
asked Sep 2, 2020 by eirikza (120 points)
3,347 questions
7,784 comments
545,026 users
