Is this possible?
We have a potential use case where we want to "natively" query AD using LDAP, but want to be able to leverage custom attributes\data in Adaxes, so wondering if we can query the LDS instance and access both native and custom attributes etc.
Many Thanks
by (1.6k points)
Yes, this is possible. You even have several options:
  • You can install only the ADSI Provider component of Adaxes on a computer without installing any other components. In this case, you will be able to access Adaxes Service installed on any computer in the same network and manipulate it using ADSI scripts. For information on how to install the ADSI API on a computer, see the following article: http://www.adaxes.com/sdk/?HowDoI.Insta ... vider.html.
  • You can install and use the Adaxes PowerShell Module and use the cmdlets contained in it to access the custom attributes. When using the cmdlets, you need to perform all operations using an Adaxes Service. To do this, pass the service address via the -AdaxesService parameter supported by all cmdlets. How to install: http://www.adaxes.com/sdk/?HowDoI.Insta ... odule.html.
  • You can access Adaxes custom attributes and other data using the LDAP protocol directly. All information is stored on Adaxes configuration server, which is an AD LDS instance installed on the same computer where Adaxes Service runs. You can use any LDAP tool or mechanism that supports management of LDAP instances to connect to it. Connection information:
    • AD LDS instance name: AdaxesBackend;
    • Connection port: see below for information on how to find it;
    • Partition name: CN=Adaxes
    • Instance administrator: the default service administrator that you specified when installing Adaxes Service.
    When connected to the specified partition, you will be able to find Custom Attributes in the following container: CN=Extending Objects,CN=Adaxes Configuration,CN=Adaxes. Each AD object that has Custom Attributes is represented as a sub-container located under the Extending Objects container. The name of the container corresponds to the Object GUID property of the corresponding AD object.
    How to find out the port used by Adaxes configuration server:
    2. Right-click your Adaxes service.
    3. Click Properties.
      The configuration server FQDN and backend port will be displayed on the General tab.
Hi all, Just wondering how I would go about connecting to Teams using Adaxes? I need to perform the following modifications to users: Set-CsUser -Identity <UPN&gt ... make Adaxes connect to Teams using the Connect-Microsoftteams command and run the above?
asked Feb 24, 2021 by TheLexicon (200 points)
#!/bin/python3 import requests import json baseUrl = "https://xxxxxxxxxx/restApi" endpoint = "/api/authSessions/create" # Request parameters requestUrl = baseUrl + endpoint ... either expired or invalid.', 'code': 'unauthenticated'} Could you please suggesst
asked Dec 26, 2022 by udathakarthic (40 points)
hi Team, I have written the code in python to fetch the members in a given LDAP group using a Adaxes API and Python3. Below is my code. I have sheilded the url and password with ... 26T14:05:59.8180694Z'} must be of type str or bytes, not <class 'dict'>
asked Sep 26, 2022 by udathakarthic (40 points)
We have internal AD that syncs to o365 via Azure AD Connect. It is not a hybrid environment; there is no Exchange on site. I am trying to find the best way to use Adaxes to ... so I am not sure the best way to handle that. Thanks for any help you can provide.
asked Apr 15, 2020 by Jasonmh (540 points)
Hello Is there any way to configure Adaxes Administration Console to automatically connect to the adaxes service after startup? That would be pretty handy. So the console can be ... which sometimes takes some time. I use version 2021.1 update 5 regards pudong
asked Mar 12, 2022 by pudong (670 points)
3,348 questions
545,047 users
