Hello
Our user can set a CustomAttributeDate attribute (user object) on the WebUI, and also change the date.
The time must always be set to 23:50.
I need a script example that can show me how to set the hour and minute part on a customattributedate attribute.
Also if the attribute is already populated with a value.
- Thanks in advance
by (2.6k points)
In your script, you can get the value provided by the user using the $Context.GetModifiedPropertyValue method. Also, you can modify the user input using the $Context.SetModifiedPropertyValue method. Here's a short sample script that does what you want:
$attributeName = "adm-CustomAttributeDate1" # TODO: modify me
$dateInput = $Context.GetModifiedPropertyValue("$attributeName")
$date = New-Object "System.DateTime" ($dateInput.Year, $dateInput.Month, $dateInput.Day, 23, 50, 00)
$Context.SetModifiedPropertyValue($attributeName, $date)
Note that a Business Rule that runs the script must be triggered before creating or updating a user.
No related questions found
3,326 questions
7,727 comments
544,678 users
