We are looking to create a dashboard that has read only capabilities. We want some IT users they are working support functions to be able to check AD data without the ability to modify any data. Is this pre-built or do you have instructions on achieving this?
by (3.2k points)
We have worked it out on our own. The interface is pretty intuitive for self teaching. Thank you.
by (270k points)
There is no possibility to achieve what you want by creating a new Web Interface. You will need to grant the IT users permissions to Read all properties of All object types. By default such permissions are granted by Domain User Built-in Security Role. If you want to create a separate Security Role for the IT users, check the following help article: http://www.adaxes.com/help/?ManageSecur ... iting.html.
You can create a new Web Interface for the IT Users and configure its Forms and Views to display all the required properties.
To create a new Web Interface do the following:
  2. Expand the Interface type drop-down list and click New.
  3. Enter the name for the new Web Interface, select an existing Web Interface to copy properties from and click OK.
  4. Once the Web Interface is created configure its Forms and Views. For information on how to do so, check the following help article: http://www.adaxes.com/help/?HowDoI.Conf ... iting.html.
  5. To grant access to the new Web Interface only for IT users check the following help article: http://www.adaxes.com/help/?HowDoI.Conf ... ccess.html.
How can I grant read only rights for Configuration items in the Adaxes Admin Console?
asked Jan 26 by mark.it.admin (2.3k points)
asked Mar 21 by EdgarsABG (50 points)
Is there a way to configure the module "Member of" in a "View user"-action as purely read only? As it stands now we are able to navigate to a seperate viewing page ... needs write-access to AD, we can't specify purely read-rights via the security role either.
asked Mar 8 by Handernye (50 points)
I added the Password last set field to the Admin view but when I click on edit it allows the admin user to change the value. Adaxes correclty handel Bad Password time and Bad password ... last set, so I guest there is a way but I can not find it. Thanks you
asked Dec 19, 2019 by tomlaf (60 points)
Create user, read only field In user creation I would like the logon name field and a few others to be read-only, is it possible? In the example of logon name, the technician ... for the field to be "gray" it sees but does not change. https://imgur.com/7DnQGtM
asked Apr 3, 2019 by user1928 (550 points)
3,326 questions
7,727 comments
544,683 users
