Seems like this was a fluke. Not sure, restarting fixed it.
Hello, When attempteing to edit the Softerra.Adaxes.Service.exe.Config file there is no listed allowedDomainControllers XML element in my file. According ... /help/?HowDoI.ManageActiveDirectory.ManageDomains.SpecifyDCsForDomain.html Thanks for your assitance!
Error occurs when trying to use SSPR from self-service web interface and from the Windows login screen. Has anyone seen this before? I haven't been able to ... configured exactly how it is laid out here: https://adaxes.com/help/ConfigurePasswordSelfService/
Hello, we have a forest with two trees that hold one domain each. There is a default tree-root trust (transitive, two-way) between the top domains. Since both trees are in ... Sid S-1-5-10 were found". Any help would be appreciated, thank you! Regards HarryNew
After disable user, not user found or show when try to enable...i follow and try many way yet still not showing.. please help i;m using the ... -not-show-disabled-account https://www.adaxes.com/help/PreventUsersFromViewingTheStructure/#change-top-level-node
Hi, looking for a solution or script to remove a user from all Online/O365/AAD groups. The article I found is not working anymore and also I didn't found any script in your repository. Thanks!
