I have a business rule that triggers on creation of a user
In its actions it:
Moves the user to a specific OU
Calls a powershell script to mailbox enable the user
Modifies the user to clear some attributes
The problem is the last action fires another business rule that I have that fires when accounts are updated
My question is this:
Can you suppress business rules from firing when the action that would normally fire it was caused by another business rule?
Thanks in advance
Phil
by (1.2k points)
I thought of something to maybe help you here. What about using an Adaxes custom boolean bit. Have you first business rule set the bit true and have the second business rule run only if not equal to true. On the second business rule that will be kicked off, have it run another action to clear the bit.
To map it a little
Set boolean bit to true
Second businees rule on modify
do this as long as boolean bit is not equal to true
Second action in second business rule
Set remove boolean bit
Does this help?
Hi, I need to retreive a secret from a Azure Keyvault in a business rule. I have a powershell script that works if i run a external command. But it fails if ... at <ScriptBlock>, <No file>: line 20 Any sugestion? Kind regards Reidar Dick-Henriksen
asked Dec 6, 2023 by reidardh (20 points)
We have employees that work at more than one location, we would like them to be on the staff lists at those locations as well as their main location. This is the ... the rules... After Alternate Location A Changed... After Alternate Location B Changed...
asked May 25, 2020 by jcalvert (60 points)
asked Mar 7 by DRiVSSi (280 points)
Hello, We have some Create Business Rules with ifs and other actions. Now these have to be controlled by a third person who has no rights to the console. How can I export the ... to a .txt file? The TXT must contain the condition and the actions. Thanks a lot
asked Aug 10, 2023 by DRiVSSi (280 points)
3,346 questions
7,782 comments
544,984 users
