I have a Business rule that does the following :
If 'extentionAttribut9' property has changed AND
the 'adm-CustomAttributeTextMultieValue1' property equals 'Add Groups' then
Execute custom command 'my custom command 1'
the 'adm-CustomAttributeTextMultieValue1' property equals 'Clone Groups' then
Execute custom command 'my custom command 2'
The problem is that I want property "extentionAttribut9" to be reset at the end of the process.
If I do it I will comes into a loop.
How can I prevent it?
Thanks in advance.
by (1.1k points)
I did somethings like this and Adaxes has somethings to prevent loop.
Added :
AND
the 'extentionAttribut9'property equals 'UserName' then
IF the 'extentionAttribut9'property does not equals 'UserName' then
Set ExtentionAttribut9 to UserName
Do we understand correctly that you want to clear the extentionAttribut9 property?
If that is correct, you can use the If extentionAttribut9 is not empty condition for both sets. To do so:
  1. Right-click an action in the set and click Add Condition.
  2. Select If <property><relation><value>.
  3. Select If Extension Attribute 9 is not empty.
  4. Click OK.
  5. Repeat all the steps for the second set and save the changes.
Also, it is not recommended to remove the If operation succeeded condition. In this case the Business Rule will trigger even if updating an object was not successful. To add the condition to both sets:
  2. Select If operation <result>.
  3. Select If the main operation succeeded.
  4. Click OK.
Thank you.
What if i need to put some other command, then too would have to follow the same guide?
Yes, you can use the same guide if you want to add another command or use another attribute.
asked Mar 7 by DRiVSSi (280 points)
Any advice would be greatly appreciated.
asked Feb 9, 2023 by Homelander90 (330 points)
I have a Rule-Based group with users. Every time a users gets added or removed from this group I want to trigger a Business Rule for "Atter adding or removing a member ... Rules be triggered by a Rule-Based group adding or removing a user? Morten A. Steien
asked Mar 27, 2023 by Morten A. Steien (300 points)
3,350 questions
545,067 users
