New user here, and I'm hoping this is an easy question:
I'm able to modify the actions available to a user before (for example) a contact is created in the Edit Home Page Actions area. However, both the Create Contact and the Create Group defaults have actions that become available after the contact or group is created. I'd like to modify what actions are available after the creation finishes - how do I modify those?
For example, using the Create Contact default action, after the contact is created the user is given the option to add the new contact to various groups. How I disable that action?
Thanks for the assistance!
by (190 points)
You can do it using Adaxes Web Interface Customization Tool. For details check the following tutorial: http://www.adaxes.com/tutorials_WebInte ... bjects.htm.
Also you might wish to customize Objects Forms. To do so, check this tutorial: http://www.adaxes.com/tutorials_WebInte ... diting.htm.
Hi, I changed the view for user -> view and would like to copy those sections to modify ... but I cant find any option? Only copy it to other web interfaces?
asked Jun 5, 2023 by wintec01 (1.1k points)
I am attempting to give some users rights to modify the report that is scheduled such as to add additional users or remove users or even move the report to a different ... i grant the rights to just modify the scheduled reports? Thank you for your help!
asked Sep 28, 2021 by mark.it.admin (2.3k points)
We recently updated the assistant field of all of our Executives using Powershell command lines and we see the field updated in Outlook, but the populated field is not showing in ... hidden field, but is there a way to show and edit this field in Adaxes?
asked Apr 7, 2021 by knowtheledge (130 points)
I'd like to implement an architecture whereby all Domain Users can request membership in any domain security group. I'd also like to allow the OU Owners to have ... from their groups without granting them the ability to remove users from all security groups?
asked Mar 25, 2020 by sirslimjim (480 points)
I am attempting to update a business rule using PowerShell to include additional approves. This is what I have so far $account = "username" # Connect to the Adaxes ... in the second code block. Any assistance would be appreciated. (love the powershell!)
asked Oct 15, 2014 by david.towle-hilt (70 points)
3,347 questions
7,784 comments
545,027 users
