I'm working on setting up business rule provisioning for Lync and UM. I've cobbled together a couple of scripts which should work by looking at them, but do not always work when initiated through the after user creation business rule. However, the same scripts work when executing manually through admin interface or website.
The first try/catch block will usually enable the user for Lync. However, the second block with Set-CsUser fails when business rule initiated with the outpur error referencing not being able to find the user. Using UPN or sip address.
Any help will be greatly appreciated.
$lyncServer = "LYNCSERVER.com"
$sessionOptions = New-PSSessionOption -SkipRevocationCheck -SkipCACheck -SkipCNCheck
$session = New-PSSession -ConnectionUri https://$lyncServer/ocspowershell -SessionOption $sessionOptions -Authentication NegotiateWithImplicitCredential
Import-PSSession -session $session -AllowClobber
$registrarPool = "POOL.LYNCSERVER.com"
$officeNumber = "%telephoneNumber%" -ireplace '.*([2-9]\d{2})(\D*)([2-9]\d{2})(\D*)(\d{4}).*', '+1$1$3$5'
$ext = $officeNumber.substring($officeNumber.length - 5, 5)
$StopLoop = $False
do{
    try{
        Enable-CsUser -Identity "%userPrincipalName%" -RegistrarPool $registrarPool -SipAddressType SamAccountName -SipDomain SIPDOMAIN.com
        $StopLoop = $True
    catch{
        Write-Host "Wait for user sync"
        Start-Sleep -s 60
While ($StopLoop -eq $False)
#wait a second
Start-Sleep -s 4
$StopLoop = $False
do{
    try{
        Set-CsUser -Identity "%userPrincipalName%" -EnterpriseVoiceEnabled $True -LineUri "tel:$officeNumber;ext=$ext" -PassThru | Set-CsClientPin -Pin #######
        $StopLoop = $True
    catch{
        Start-Sleep -s 60
by (1.2k points)
As far as we can see from the steps you tried to rectify the issue, you are experiencing a replication issue. Most probably, the root cause for it is that Adaxes creates a new user on one of your domain controllers, while Lync uses another DC to enable a Lync account for the user and set the properties. The best strategy for mitigating the issue would be to make Adaxes and Lync use the same DC instead of adding wait loops. Almost all Lync Management cmdlets support the -DomainController parameter that allows specifying the DC that will be used by Lync to perform the operation. Thus, you need to pass the DC where Adaxes creates the user as a paramter to the cmdlets. We've modified your code to pass the DC to the cmdlets as follows:
# Get telephone number and extension
# Get domain controller FQDN
$rootDSE = $Context.BindToObject("Adaxes://$domainName/rootDSE")
$domainControllerFQDN = $rootDSE.Get("dnsHostName")
Enable-CsUser -Identity "%userPrincipalName%" -RegistrarPool $registrarPool -SipAddressType SamAccountName -SipDomain SIPDOMAIN.com -DomainController $domainControllerFQDN
Set-CsUser -Identity "%userPrincipalName%" -EnterpriseVoiceEnabled $True -LineUri "tel:$officeNumber;ext=$ext" -PassThru  -DomainController $domainControllerFQDN | Set-CsClientPin -Pin #######
Hello, I am scripting user creation. I have created a custom command where an end user will submit info for the user to be created from: Here is the scirpt: # Import the ... Schema. I have tried using "Employee Type" as in the screen shot above but same error.
asked Apr 6, 2023 by mightycabal (1.0k points)
I'm seeing this error when I run a user deprovision. It still executes the script but nobody likes errors! Run PowerShell Script 'DuoDeprovisionExport' For the user. The term ' ... running an export script in the first place for my Duo user info. ) Thanks.
asked Feb 19, 2020 by rainamaina (60 points)
We were wondering if Adaxes has a script available to create AS400 accounts during the AD creation. This will allow us to totally automate the new hire process going forward.
asked Jan 26, 2017 by willy-wally (3.2k points)
I need to replace one Active Directory security group that has been given rights over many OUs within several Security Roles. There are likely ~300 entries that need ... in the SDK documentation appears to be broken - http://adaxes.com/scriptrepository
asked May 1, 2013 by SomeUser (90 points)
Hi all, I get the error below when enabling a user for Lync. I have opened port 5986 for winrm over https and have verified the correct certificates ... winrm quickconfig -transport:https". For more information, see the about_Remote_Troubleshooting Help topic.
asked May 8, 2017 by joshua.amune (50 points)
3,346 questions
7,779 comments
544,979 users
