Is it possible to modify a property pattern drop down list from the web interface?
Thanks.
by (840 points)
No, this can be done only in Adaxes Administration Console.
Adaxes uses a property pattern file for creating and modifying an user. Is it possible to have a property pattern file for creating or modifying only? I try to achieve the ... required when an user is created but not required when an user is modified... Remco
asked Dec 8, 2013 by RTiel (780 points)
asked Mar 8, 2022 by Keonip (160 points)
Hi I need to update some property patterns on a scheduled basis and am doing this via a powershell script. The particular attibute will be a drop down, but ... t work! $item.SetConstraints($constraints) $item.SetInfo() $userPattern.Items.Add($item) Thanks Matt
asked Nov 11, 2020 by chappers77 (2.0k points)
Is there an option to load the possibles values of the Property Pattern, from SQL or other external sources?
asked Aug 5, 2013 by sdavidson (730 points)
Hi, is it possible to use custom Powershell script to determine, who will be able to modify AD object property (for example managedBy)? So it is not manager of given object who can edit this property, but anyone who pass checks in Powershell script..
asked Apr 7, 2020 by KIT (910 points)
3,346 questions
7,779 comments
544,979 users
