Hi
This stores the old name correctly.
This stores the new name, even though it fires "Before" renaming the group ?
How do I store the old name for the group ?
I'm currently renaming the objects from the Console, but later on - renaming these objets will be done from the WebUI too.
- Thanks
by (2.6k points)
You can use the following script instead of the standard action:
$Context.TargetObject.Put("adm-CustomAttributeText30", $Context.TargetObject.Get("name"))
$Context.TargetObject.SetInfoEx(@("adm-CustomAttributeText30"))
To add the script to your rule, use the Run a program or PowerShell script action.
Hi! Can ADAxess be used to populate a AD group with computer objects who's name partly matches a AD username from another group? I'e let say we have a group named ' ... channel until problem is solved by just adjusting which group they belong to .... /Kaj
asked Jun 12, 2018 by KajLehtinen (650 points)
Just recently upgraded to 2018.1 When I create a new user from a user template, it's not working correctly. I created a user called Sams Club. And look at the image ... User Creation" business rule. When I don't use a template everything works fine though.
asked Jul 22, 2018 by rurbaniak (1.4k points)
Dear Support We have a business rule in the old Adaxes 2017 that was working: Before adding a universal security group to a global security group, the group type of the ... adding a universal group to a global group? <br> Our action: Best regards Johann
asked Nov 30, 2021 by Johann Ihnen (170 points)
We are trying to mass change user photos through a scripted method. We are using a modified version of the Import User Photo and Optimize User Photo scripts. ... { $newJpegPicture.Dispose() } if ($newThumbnailPicture) { $newThumbnailPicture.Dispose() } }
asked Mar 10, 2019 by polley (1.2k points)
Hello, I would like to ensure that before a computer object is moved in Adaxes, the user must enter a ticket number, and after the input, the PC is moved to ... prompts the user to enter a ticket number before the move/delete operation? Kind regards, Fabian
asked Mar 20 by fabian.p (150 points)
3,349 questions
545,063 users
