We have come across an issue we need assistance with. We would like to add a process in the deprovisioning to Cancel all reoccurring or non reoccurring meetings for the user. We have orphaned meetings tieing up rooms.
by (3.2k points)
Any ideas?
We created a script that deletes meetings scheduled for an Office 365 mailbox. See it in our Script Repository: http://www.adaxes.com/script-repository ... r-s426.htm.
You can add the script to the Custom Command used for deprovisioning employees. To do this, use the Run a program or PowerShell script action.
We recommend setting the $startDateProperty parameter of the script to adm-CurrentDateTime and the $endDateProperty parameter to $NULL.
Do you have a version for on prem Exchange?
We don't have one, but we'll make it for you.
We appreciate it. Thank You
We've added the required script. see section Script for Exchange On-Premises here: http://www.adaxes.com/script-repository ... onpremises.
Is this script no longer available? I was looking for a script for exchange 2016.
+1
There is no need to use scripts any longer. You can use the dedicated action: image.png
asked Apr 22, 2020 by RayBilyk (230 points)
When we deprovision a user the member of groups are deleted and the power shell scrips only runs as removing all memberships. I can't see what was removed. Is there a scrips I can run prior to removing those memberships that will e-mail what they are?
asked Oct 15, 2019 by meyerm (50 points)
Hello All, is is possible via Adaxes deprovisioning to remove all his Azure and M365 roles besides custom Powershell script? Regards Ivaylo
asked Mar 31, 2023 by ivaylo.valkov (100 points)
I would like to know if it is possible to use powershell to schedule an appointment in the outlook calendar with variables and send it via exchange Thanks in advance, Simone
asked Sep 22, 2021 by Simone.Vailati (430 points)
asked Jan 4 by cewilson (140 points)
3,346 questions
7,782 comments
544,987 users
