Hi folks,
I already have a great script (thank you) that monitors our HR system for adds/removes/changes of our staff and reflects those changes in AD via scheduled task.
I would like to setup a Business Rule that monitors "AFTER CHANGING LOGON NAME OF USER", the home directory of that user will be 'renamed' to the new logon name.
eg.
username = jsmith home drive = \\server\users\jsmith
user gets married and changes name to jblack. Existing daily script will pick up this change in the HR system and will amend the account (name, display name, logon name etc etc). HERE is where the business rule will be invoked and will rename the existing home drive folder (jsmith) to jblack
result - username = jblack home drive = \\server\users\jblack
Or, is there a more efficient way of doing this? Could I possibly incorporate it into the existing script?
Corey
by (170 points)
Hello Corey,
The best way to achieve what you want is to create a Business Rule triggered after changing a username. To create such a Business Rule:
  3. On the 3rd step, add the Run a program or PowerShell script action and paste the following script that renames a user's home folder:
     $homeDirectoryPath = "%homeDirectory%"
     # Check whether the home directory exists
     if(!(Test-Path -Path $homeDirectoryPath))
         $Context.LogMessage("The home directory path is invalid", "Warning")
     # Rename the home directory
     $homeDirectory = Get-Item -Path $homeDirectoryPath
     $newHomeDirectoryPath = $homeDirectory.Parent.FullName + "\%username%"
     $Context.TargetObject.MoveHomeDirectory($newHomeDirectoryPath, $NULL)
  5. Now, you need to configure when the home folder must be renamed. Right-click the action you've just added and click Add Condition.
  6. Select the If <property> changed condition type.
  7. Specify If User Logon Name (pre-Windows 2000) has changed.
  8. Click OK.
  9. Also, you need to run the script only if a user has a home folder. Right-click the action and click Add Condition again.
  10. Select the If <property> <relation> <value> condition type.
  11. Specify If Home Directory is not empty.
  12. Click OK and finish creation of the Business Rule.
Perfect as usual.
Thanks guys. Always a great help.
I am using this script modified for my testing. Import-Module Adaxes $csvFilePath = "D:\TestFeed\ImportNewUsers.csv" # Path to pick up feed file $userIdColumn = "Employee Number" # TODO: ... initial. I would like to add a 2 for now if the sam isn't unique.
asked Oct 17, 2022 by mightycabal (1.0k points)
Hi We've had a request to forward to a mailbox any user who has had their username and email address changed, the email is to show old user name, new user name, old ... and email address, would it need to be a Powershell script for this? Thanks in advance.
asked Jan 23, 2015 by CBurn (700 points)
Hello We are using the built in Copy command to copy users but have run into an issue. We get the error 'can't create a home drive because it already exists'. No ... trying to create the original users home drive again. Is there any way round this? Thanks.
asked Mar 2, 2015 by CBurn (700 points)
Good Morning, I've been working through some of my processes and I'm not looking to make sure the deletion of Home directories (both remote and standard) as well as ... for user deletion. If there are any questions or clarification needed, please let me know.
asked Oct 16, 2015 by jtop (680 points)
Hi, I'm new to this forum so I hope this question hasn't already been answered. The sceanrio is that the Adaxes servert is part of domain A and is used to ... , ObjectInherit", "None", "Allow") $acl.AddAccessRule($rule) #Commit Changes Set-Acl $userHome $acl
asked Dec 8, 2014 by niclas.eriksson (260 points)
3,326 questions
7,727 comments
544,679 users
