How Adaxes communicates with AD? Is the connection secured?
FAQ section
Postby Support » Thu Oct 14, 2010 5:58 am
Adaxes service uses the LDAP protocol to communicate with Active Directory. Interaction between the Adaxes service and Active Directory is secured for security-sensitive operations only. For example, prior to change or reset a password for an AD user, an SSL connection is established and the data are sent via an encrypted channel.
Interaction between Adaxes clients and Adaxes services is always performed using an encrypted TCP channel.
Active Directory Identity Management
Follow Adaxes in social networks
Image Image Image Image
User avatar
Support
Site Admin
Return to FAQ [read only]
Who is online
Users browsing this forum: No registered users and 0 guests
cron
