I think I am not the only one disliking the new design, even though functionality is superior to the older one, but this is only due to practical reasons - I do really get lost which section I am looking at, there is just too much white space...
There is a really nice and clear design on /Adaxesconfig which has well defined sections, so if the same design could be applied for main web interface too it would be perfect!
If there are any registry tweaks, manual IIS config or file replacement to get that design, I am willing to go that route, that is how frustrated I am with current design.
Are there any options to get that?
by (760 points)
Hello!
Could you, please, provide some examples of Web Interface sections you would like to improve and a brief description of how you would like them to be improved?
Unfortunately, there is no such possibility. However, you can set custom colors in your Web Interface. For details, have a look at the following tutorial: https://www.adaxes.com/tutorials_WebInt ... Colors.htm.
My issue is regarding visual borders, the new design has basically none and that frustrates people.
So if sections in user properties which look like this:
Could have sections framed and colored like this:
This would be a big improvement on quickly finding needed information in the page and distinguishing which section it belongs to.
by (270k points)
Thank you for the details. We will consider the suggestion for future releases of Adaxes.
Hello I'm a little (no, actually very) concerned about upgrading 2017.2 to 2018.1, because I am unsure how an upgrade will impact on our current solution (web UI) ... Anyone that have some experience about upgrading to version 2018.1 in this respect ? - Thanks
asked Sep 13, 2018 by Boxx.dk (2.6k points)
When setting a default OU for new user creation, our domain does not expand. Editing users is fine, installed console is fine. Config was working before upgrade to 2018.1. Any suggestions?
asked Jul 17, 2018 by polley (1.2k points)
Hi Just upgraded to 2018.1 Seems that backing up the web interface works differently than in 2017.2? How do I back up my web configuration now ? Thanks in advance!
asked Jul 4, 2018 by pafa (500 points)
There seems to be a bug in the email being sent to approvers - the link for the selfservice portal is not reflecting the change in the IIS configuration - it still points ... the link to the selfservice portal they will get a 404 - File or Directory not found
After upgrading to 2018.1 I'm getting an error of "Your password must be changed before you can log in. The Change Password operation is disabled in the Web Interface." when ... my password. I cannot find the setting to enable this. Has anyone else seen this?
asked Jun 28, 2018 by jake_h (300 points)
3,326 questions
7,727 comments
544,679 users
