Adaxes Web Interface Compatibility Issues with Safari
Known issues and bugs
Post Reply
User avatar
Support
Site Admin
Fri Dec 02, 2016 5:30 am
SYMPTOMS
  • Search and Reports get stuck displaying Loading message and return no results.
  • Drop-down menus are not displayed.
  • Nothing happens when clicking operations (Edit, Reset Password etc.) in the object view for user accounts.
  • In the object view for user accounts, properties are not displayed in sections.
  • Hints and help for object properties are not displayed.
CAUSE
Adaxes Web Interface is built on ASP.NET that does not correctly recognize the latest versions of the Safari browser.
WORKAROUND
To work around the issue, you need to add Safari 8 browser configuration file for Adaxes Web Interface:
  1. Close the Web Interface Customization Tool.
  2. Download the archive and unpack it.
  3. Copy the safari.browser file to folder C:\Program Files\Softerra\Adaxes 3\Web Interface\<Web Interface type>\App_Browsers on the computer where the Web Interface is installed.
  4. Open the folder.
  5. Update the modification date of ie.browser file, for example:
    • Open the ie.browser file with a text editor.
    • Save the file without making any changes.
Active Directory Identity Management
Follow Adaxes in social networks
Image Image Image Image
Post Reply
  • Information
  • Who is online
    Users browsing this forum: No registered users and 0 guests
