In the previous version of Adaxes <2018 we could right click and copy/paste a form from one interface to the other.
Since the 2018 version with the web console we have to use the drop down list with this two options:
- Apply to other Web Interfaces
- Copy settings from another Web interface
I tried both and it has replace my entier interface by the one I copied, what I expected was to only add the specific action I've selected. :?
So how do I copy/paste a specific action form another web interface?
by (440 points)
Hello Alex,
Unfortunately, there is currently no possibility to copy actions from one Web Interface to another. The feature will be introduced in the next release of Adaxes which should be available within about a month.
Thanks for the information.
Hopefully the next release will also fix the extreme slowness of the admin interface from Edge/IE/Firefox. It's very frustrating working like that.
Hello Alex,
Could you, please, specify what exactly you mean by “slowness of the admin interface”? Is it about the Web Interface Configurator? What exactly is slow? Any additional details would be very helpful.
Yes the /adaxesconfig URL.
It's just very slow (3-5 seconds between each click) from Edge, from Firefox, same behaviour and I'm using a recent versions of those browsers from a Windows 10 OS.
By the way the new UI could also be improved, there is too many wasted space. Now we have to scroll to look for all the functions because there's huge margin between each category and it doesn't use the width efficiently at all. 95% of the population would be on a 16:9/1080p display but the interface is optimized for a 4:3/280p display.
Hello Alex,
Thank you for clarifying.
Most probably the behavior is caused by the number of Custom Commands you have. It was fixed in the latest version of Adaxes. You can download it here: https://www.adaxes.com/download.htm.
Hello Alex,
I'm on the 3.10.16008.0 and the link is for the 3.10.16429.0 release, can you tell me if there is anything worth making an update for this minor version ?
Hello Alex,
As we mentioned earlier, version 3.10.16429 includes Adaxes Web Interface Configurator performance enhancements. The configurator should work much faster than in your current version (3.10.16008.0). For more details, check section Update 2 of Adaxes 2018.2 What's New: https://www.adaxes.com/info_whats-new_2 ... tm#update2.
Hello Alex,
Adaxes 2019.1 which includes the possibility to copy actions between Web Interfaces is now available. You can download it here.
What's New | Upgrade Instructions
Is there a easy to copy changes between interfaces? looking to have a test web interface then promote or copy the changes to the Active interface technicians are using.
asked Mar 1, 2018 by kevball2 (100 points)
Hi - How can I remove the option of allowing "Copy User Groups" during the copy user process in the interface. I'd like to have it hidden but still active so to not allow our HR team to accidently unclick it during the process.
asked Oct 15, 2019 by 6FigureMission (140 points)
Hi, Is it possible to copy an AD object from within the Web interface?
asked Aug 8, 2011 by nsd1915 (20 points)
Hi all, I setup some rule-based groups and tried to copy criterias from group A to B. I did it via "copy" and "copy as plain text" option, but everytime pasting is failing : ( Any clue or idea why?
asked May 26, 2023 by wintec01 (1.1k points)
I'm trying to combine these two scripts to effectively store a user's group memberships in customattributebinary5 and then be able to copy and paste those memberships to a ... ) $Context.LogMessage("Added the user to group '$groupName'", "Information") }
asked Jan 24, 2020 by yourpp (540 points)
3,348 questions
545,055 users
