Hey All. I know ADaxes is like the best thing since sliced bread for many users here so I'm hoping you can assist with a question. I am currently trialing out the software in hopes that I can get it approved for next years budget. I am working on getting as much automated as I can to prove worth.
A simple task that I'm working on is User Creation. By default when you create a new user, step one is selecting the ou within the form for the user to be created in. I would like to skip this step by default and have a Business Rule move the user to the correct OU based on the 'Office' Property that is selected from a list. Is this possible? I created a ticket with Support earlier today, but they haven't gotten back to me(not complaining since i'm on a trial)
Also has anyone utilized a script to setup an AS400 from within ADaxes as well and have any tips in how to do so? I'm hoping I can get this automated as well. Basically our AS400 just needs a user id input, ad username input, and the employee id so that it can create the user. We then have a application that we configure more permissions on that talks to the AS400. Luckily my manager was an AS400 programmer back in the day so if we can get some sample script, we can hopefully convert it to work for us
by (50 points)
Yes, it is possible. To skip the destination container selection, you need to specify the default container in the settings of the Web Interface action used for creating new accounts. For details, see https://www.adaxes.com/tutorials_WebInt ... -selection. You will need to enable option Select the following container by default, specify the destination container and then select Always use this container.
For information on how to automate moving users to specific containers, have a look at the following tutorial: https://www.adaxes.com/tutorials_Automa ... lUnits.htm.
Could you, please, provide us with the ticket number and the email address that was used to submit the request?
As per our check, AS400 has an API which allows you to send requests to it from Adaxes using PowerShell scripts. You can check the software documentation here: https://www.ibm.com/support/knowledgece ... elcome.htm. Also, the following script from our repository should be helpful: https://www.adaxes.com/script-repositor ... 0-s414.htm.
We've uninstalled the previous version via the "add/Remove Programs" feature in Windows 10, but we still get an error saying that another version of the client is still installed and won't allow us to run the .MSI installer. How can we get around this?
asked Feb 15 by MShep (80 points)
The checkbox is not selected (False) by default.
asked May 30, 2022 by john.harding (70 points)
When we deprovision a user the member of groups are deleted and the power shell scrips only runs as removing all memberships. I can't see what was removed. Is there a scrips I can run prior to removing those memberships that will e-mail what they are?
asked Oct 15, 2019 by meyerm (50 points)
You do not need to create a trust between AD domains to manage them with an Adaxes service. When registering an AD domain, an account with administrative permissions ... control the user access to the managed resources, the Adaxes service uses Security Roles.
asked Apr 29, 2009 by Adaxes (550 points)
3,349 questions
545,066 users
