I try to change the script from Report 'Inactive users' to get only users which are located under an specific "Admin" OU.
I can't use "Look in" because we manage 20 small Domains and I can only pick one Admin OU at a time.
So I try to change the filter part, add $filterAdminOU = "(ou:dn:=Admin)" -> didn't work.
I can't find the failure :(
# Build search filter
$threshold = (Get-Date).AddDays(- $days)
$thresholdInt64 = $threshold.ToFileTime()
$thresholdGeneralizedTime = [Softerra.Adaxes.Utils.Transform]::ToGeneralizedTime($threshold.ToUniversalTime())
$filterUsers = "(sAMAccountType=805306368)" # all user objects
$filterCreatedBefore = "(whenCreated<=$thresholdGeneralizedTime)"
$filterNoLastLogonTimestamp = "(!(lastLogonTimestamp=*))"
$filterLoggedOnBeforeTimestamp = "(lastLogonTimestamp<=$thresholdInt64)"
# The report is based on the lastLogonTimestamp attribute, which is replicated across all DCs.
# The lastLogon attribute is not replicated but contains the exact time when a
# user logged on the DC Adaxes is connected to. Using the attribute in search filter makes
# report results more accurate.
$filterNoLastLogon = "(!(lastLogon=*))"
$filterLoggedOnBefore = "(lastLogon<=$thresholdInt64)"
$filterPasswordChangedBefore = "(pwdLastSet<=$thresholdInt64)"
$filter = "(&" +
    $filterUsers + $filterCreatedBefore + $filterAdminOU +
    "(|" + $filterNoLastLogonTimestamp + $filterLoggedOnBeforeTimestamp + ")" +
    "(|" + $filterNoLastLogon + $filterLoggedOnBefore + ")" +
    $filterPasswordChangedBefore + ")"
regards
Helmut
by (510 points)
Ok, I found "Support for Extensible Match Search Filters are limited, Microsoft's Active Directory for instance does not support this (reference)."
Can I filter the search result like in Powershell | where { $_.CanonicalName -like "*/Admin/*" }
regards
Helmut
Hello Helmut,
To achieve what you need, we recommend using a Business Unit as the report scope. For information on how to create Business Units, have a look at the following tutorial: https://www.adaxes.com/tutorials_Active ... tively.htm. The Business Unit should contain the users located in the Admin OUs in all the domains.
Dear Adaxes Support, I'm trying to check the uniqueness of the Initials-proberty. My script works well so far. Import-Module Adaxes $value = $Context.GetModifiedPropertyValue("initials"); if ( ... Have you a idea how I can do this in the right way? Thanks :-)
asked Aug 13, 2013 by Napoleon (700 points)
Hello dear ADAXES community, what i wanted to do is, to have a custom report which does the following: get every group in a specific OU (the OU comes from an adaxes custom ... Add($Group.name) } } is this possible in such a way? thank you for your help
asked Sep 23, 2020 by m_st (200 points)
Hello, The report named Inactive users allowed to log in shows the Active Directory sign-in (Last-Logon-Timestamp) and Azure AD sign-in (Last Logon) but only for Active Directory ... updated by an Azure logic App. But we'd love to have this natively in Adaxes.
asked Dec 13, 2022 by Gavin.Raymen (40 points)
3,346 questions
7,768 comments
544,965 users
