Dear Support,
I have a PS script, which as result has a DataTable of assets assigned to user in external system.
I would like to show this data in Web interface - so a script based report was my first thought.
Can you please advise how to properly show the DataTable in script based report?
Thank you!
by (920 points)
Hello Dmytro,
You can connect to the external system in your script, get information from the DataTable and then add the information to corresponding report custom columns. For information on how to work with DataTables, you can check the following Microsoft article: https://docs.microsoft.com/en-us/dotnet ... mework-4.8. For details on creating reports, have a look at the following tutorial: https://www.adaxes.com/tutorials_Active ... Report.htm. The following part of the tutorial shows different approaches for adding items to reports: https://www.adaxes.com/tutorials_Active ... #collapse5.
We would like to use the "Rule Based Groups" functionality that Adaxes has to create distribution groups where we have one group per manager and the members are the user ... so that the link doesn't break when changes happend to the managers AD object?
asked Oct 27, 2021 by odsven (1.8k points)
We have the following script we need fixed to run within Adaxes to add true/false value to a customattribute for use in building dynamic distribution lists. $users = ... } else { Set-Mailbox -Identity $user.Name -CustomAttribute8 "Individual contributor" } }
asked Jul 13, 2022 by willy-wally (3.2k points)
Hi smart people! I'm using this script: http://www.adaxes.com/script-repository ... t-s423.htm Which works great for sending an email to someone, listing their direct ... body of the email at once would be greatly appreciated! Thanks for any and all replies!
asked Mar 24, 2017 by 3Jake (150 points)
Hi team, I have a few questions about approval flows How can I send approval to individual user (stored in an custom attribute)? How can I do actions based on request is ... -> set accountExpire +6 Months if denied -> do nothing and account will expire
asked Mar 13 by wintec01 (1.1k points)
3,346 questions
7,782 comments
544,986 users
