Add users to group in bulk
The script adds users to an AD group in bulk. Users are identified by their sAMAccountNames specified in a custom attribute of the group. To execute the script, you can create a business rule triggered After creating a group or After updating a group.
Parameter:
  • $propertyForUsernames - Specifies the LDAP name of the property that will be used to specify sAMAccountNames the users to add to the group. sAMAccountNames in the property must be separated by commas (e.g. user1,user2,user3).
$propertyForUsernames = "adm-CustomAttributeText1" #TODO: modify me
function SearchObjects($filter)
    $searcher.SizeLimit = 2
    $searcher.VirtualRoot = $True
        # Execute search
        return ,$searchResults
        # Release resources
# Get usernames from the custom attribute
    $sAMAccountNames = ($Context.TargetObject.Get($propertyForUsernames)).Split(",")
# Get the current group members
    $memberGuidsBytes = $Context.TargetObject.GetEx("adm-DirectMembersGuid")
    $memberGuidsBytes = @()
$memberGuids = New-Object "System.Collections.Generic.HashSet[System.Guid]"
$memberGuidsBytes | %%{ $memberGuids.Add([Guid]$_) }
foreach ($sAMAccountName in $sAMAccountNames)
    $searchResults = SearchObjects "(sAMAccountName=$sAMAccountName)"
        $Context.LogMessage("Account with username $sAMAccountName not found.", "Warning")
    elseif ($searchResults.Length -gt 1)
        $Context.LogMessage("Found more than one account with username $sAMAccountName", "Warning")
    # Add the user to the group
    $userGuid = [Guid]$searchResults[0].Properties["objectGUID"].Value
    if (-not($memberGuids.Contains($userGuid)))
            $Context.TargetObject.Add("Adaxes://<GUID=$userGuid>")
            $Context.LogMessage("An error occurred when addingaccount with username $sAMAccountName to the group. Error: " + $_.Exception.Message, "Warning") # TODO: modify me
        $Context.LogMessage("User $sAMAccountName is already a member of the group.", "Information") # TODO: modify me
# Clear custom attribute
$Context.TargetObject.Put($propertyForUsernames, $NULL)
$Context.TargetObject.SetInfoEx(@($propertyForUsernames))
Comments 0
