The script exports values of custom attributes of an Active Directory object to a CSV file.
Custom attributes and not stored in AD, but can be used in Adaxes the same as any other attributes of AD objects. They are provided by Adaxes and stored on Adaxes Service backend server (AD LDS).
Parameter:
- $csvFilePath - Specifies a a template for the CSV file path that will contain custom attributes of an AD object. You can use value references (e.g. %username%) to insert properties of the object as a part of the path.
Adaxes version 2017.2 and earlier
$csvFilePath = "\\server\share\CustomAttributes_%name%.csv" # TODO: modify me
function GetAttributeValue ($attributeName)
$value = $Context.TargetObject.Get($attributeName)
$value = $NULL
return $value
$customAttributesInfo = @{
"adm-CustomAttributeText" = 1..30
"adm-CustomAttributeBoolean" = 1..25
"adm-CustomAttributeDate" = 1..5
"adm-CustomAttributeInt" = 1..5
"adm-CustomAttributeTextMultiValue" = 1..10
"adm-CustomAttributeTimestamp" = 1..5
# Get display names for all attributes
$culture = [System.Globalization.CultureInfo]::CurrentCulture
$attributeFriendlyNamesCache = [Softerra.Adaxes.Directory.AttributeFriendlyNamesCache]::GetInstance($culture)
# Build report
$records = New-Object System.Collections.ArrayList
foreach ($attributeNameTemplate in $customAttributesInfo.Keys)
$attributeNumbers = $customAttributesInfo[$attributeNameTemplate]
foreach ($number in $attributeNumbers)
$attributeName = "$attributeNameTemplate$number"
$value = GetAttributeValue $attributeName
if ($value -eq $NULL)
if ($attributeNameTemplate -eq "adm-CustomAttributeTimestamp")
switch ($value)
"0"
$value = "Never"
"9223372036854775807"
$value = "Never"
default
$value = [DateTime]::FromFileTimeUtc([Int64]::Parse($value))
if ($attributeNameTemplate -eq "adm-CustomAttributeTextMultiValue")
$value = [System.String]::Join(";", $value)
if ($attributeFriendlyNamesCache.HasFriendlyName($attributeName))
$attributeName = $attributeFriendlyNamesCache.GetFriendlyName($attributeName, $Context.TargetObject.Class)
$record = New-Object PSObject
$record | Add-Member -MemberType NoteProperty -Name "Name" -Value $attributeName
$record | Add-Member -MemberType NoteProperty -Name "Value" -Value $value
[void]$records.Add($record)
if ($records.Count -eq 0)
$Context.LogMessage("The object does not have any custom attributes specified.", "Information")
# Export report to CSV
$records | Export-Csv -Path $csvFilePath -NoTypeInformation
Adaxes version 2018.1 and later
$value = $NULL
return $value
$path = $Context.GetWellKnownContainerPath("ConfigurationSetSettings")
$configurationContainer = $Context.BindToObject($path)
$attributeFriendlyNames = $configurationContainer.GetAttributeFriendlyNames($culture.ThreeLetterISOLanguageName, "ADM_GETATTRFRIENDLYNAMESMODE_MERGED")
$attributeFriendlyNamesMap = @{}
foreach ($attributeFriendlyName in $attributeFriendlyNames)
$ldapPropertyName = $attributeFriendlyName.AttributeName
$typeSpecificFriendlyNames = $attributeFriendlyName.TypeSpecificFriendlyNames
if ($typeSpecificFriendlyNames.Length -eq 0)
$attributeFriendlyNamesMap.Add($ldapPropertyName, $attributeFriendlyName.GenericFriendlyName)
$friendlyName = $NULL
foreach ($type in $typeSpecificFriendlyNames)
if ($type.ObjectType -ne $Context.TargetObject.Class)
$friendlyName = $type.FriendlyName
break
if ($friendlyName -eq $NULL)
$attributeFriendlyNamesMap.Add($ldapPropertyName, $friendlyName)
# Build report
switch ($value)
"0"
$value = "Never"
$value = "Never"
default
if ($attributeFriendlyNamesMap.ContainsKey($attributeName))
$attributeName = $attributeFriendlyNamesMap[$attributeName]
