Hi all,
I'm facing an issue when adding a new Adaxes service. I already have 3 adaxes Services and I need to setup a new one.
The installation process stuck for hours at step 'Installing AD LDS instance' without any errors in event log (System, Application Adaxes ...)
I tried to disable Windows FW on each server without success.
Which port should I test ?
Have you any idea ?
I already installed 3 other Adaxes services without prblem... :/
Thanks in advance
regards
by (740 points)
Can you try installing Adaxes with detailed logging. To do this:
  1. Start installation using the following command line: msiexec /i C:\Installs\adaxes_x64_en.msi /lvx C:\Logs\adaxeslog.txt, where:
    • ​C:\Installs\adaxes_x64_en.msi​ - is the full path to the Adaxes installation package,
    • C:\Logs\adaxeslog.txt - is the full path to the log file generated during the installation.
  2. Proceed with installation.
  3. As soon as installation sticks, check the generated installation log for the latest error or send the log file to us to support[at]adaxes.com.
Is the further clarification on how to join the Adaxes service to the configuration set during a multi-sever upgrade
asked Nov 16, 2022 by itsupport (20 points)
I'm looking for installation/configuration manuals to determine the installation requirements (prerequisites) for Adaxes. I'd like to install this on two vmware virtual servers running Windows ... ready for the install so I don't waste any of the trial time.
asked Apr 27, 2021 by MRBruce (110 points)
Hi, I'm trying to fully automate the deployment of Adaxes (using windows DSC ressources). I was able to setup servers with only the front-end features, but cannot ... relevant information in the forum or online about giving the credentials to the installer...
asked Jul 13, 2017 by thomas.laborde (100 points)
Hello, Where i'm actually working, it seems there is an "old dev" Adaxes environnement which was linked to the AD. The server has been deleted now, but it seems the Windows ... Even if i install a fresh client. Where those parameters came from a GPO i guess ?
asked Apr 26, 2016 by Alexandre (460 points)
3,362 questions
7,812 comments
545,226 users
