We have been using Business Rules for newly created/changed active directory objects successfully for sometime now. In our current environment, most of our user objects are being created from an external IdM solution and not from Adaxes directly. Is there a way to leverage a Business Rule to detect the creation of a user object that was created outside of Adaxes? Or is this better handled by a scheduled task to process newly created users?
by (70 points)
A Scheduled Task or Tasks seem to be one of the possible options in this case.
Another option would be to use Custom Commands and Adaxes ADSI provider. The ADSI provider exposes a set of COM Automation objects that can be used to access Adaxes functionality from any language that supports COM, such as VBScript, PowerShell, C++, and .NET languages like VB.NET and C#. If your IDM solution provides a scripting language that can make calls to COM objects, you can create Custom Commands with all actions required to provision a new user, and then execute the commands via the Adaxes ADSI Provider on each new user created by the IDM solution.
For more information on Adaxes ADSI Provider, have a look at the following article from our SDK: http://www.adaxes.com/sdk/?WritingAdsiScripts.html. In this article, you will find information on how to execute a Custom Command on an AD object using PowerShell: http://www.adaxes.com/sdk/?SampleScript ... mands.html.
Good Morning, Interesting issue, newly created users created in Adaxes don't show AD group membership when viewing in Adaxes but the groups show normally in AD. Users ... idea why users crearted in Adaxes cannot see the groups while other users appear fine?
asked Aug 2, 2023 by curtisa (210 points)
I have a Business Rule in place that after a new user is created, will create an Exchange mailbox for the user, set the Retention Policy for the user, then send them a ... the correct email address for the user. Is this maybe just a timing issue or something?
asked May 16, 2014 by RickWaukCo (320 points)
Hi, I'm trying to create a business rule that basically says if a user is a member of group a, they can't be a member of group b. Optionally would also like to ... removed from group a. Can i get some guidance on how I could accomplish this in adaxes?
asked Mar 14, 2022 by blaiseb (120 points)
I'm configuring a new domain with Adaxes 2017.1 from scratch and am trying to properly establish user tasks in as streamlined a fashion as possible, and I have some ... AD, but will not update the Exchange side to match. Any assistance would be appreciated!
asked Aug 8, 2017 by ctdhelpdesk (190 points)
Hello, we manage 20 Domains with Adaxes. How can we create a Business Unit that holds all objects within OU's /Builtin and Users of all managed Domains without adding each OU seperately? regards Helmut
asked Jan 21, 2021 by a423385 (510 points)
3,351 questions
545,079 users
