I've test auto users desactivation, but mess with some conditions.
So i think i've got all of my users with "When Marked Inactive" adaxes properties fill with today date.
How can i clear this field for all my ad users ?
Best regards
by (190 points)
Hello Nicolas,
For this purpose you need to create a Custom Command and execute it on all users.
i. Create Custom Command
To create a Custom Command that remove the When Marked Inactive attribute for a user:
  2. On step 2 of the Create Custom Command Wizard, select User.
  3. On step 3, add the Update the User action.
  4. Click Add.
  5. Expand the Property to modify drop-down list and select Show all properties.
  6. Select When Marked Inactive.
  7. Select Remove the property.
  8. Click OK 2 times.
  9. Double-click Always.
  10. Select If <property> <relation> <value>.
  11. Specify If When Marked Inactive is not empty.
  12. Click OK, then Next, then Finish.
ii. Execute the Custom Command on all users
To execute the command on all users managed by Adaxes:
  1. In the Console Tree of the Administration Console, navigate to and right-click the Active Directory node. Select Find.
  2. In the Type drop-down list, select User.
  3. Click Find Now.
  4. When search is complete, select all the users found (Ctrl+A).
  5. Right-click the user list and select All Tasks \ My Custom Command, where My Custom Command is the name of the command you created on step i.
Hi, Im using the "When Marked Inactive" custom property that comes with Adaxes. Im trying to test out the deletion of users using that "When Marked Inactive" attribute, but ... if there is a way to see visually that custom attribute on my disabled Test user.
asked Oct 10, 2022 by raul.ramirez (210 points)
I have struggled with this custom Adaxes property a little, because it is useful in deprovisioning. When looking at User accounts, the property works via a scheduled task or custom ... a bug? And, will it be possible to look at Adaxes properties in the GUI?
asked Feb 24, 2014 by JoeC (470 points)
Hello, is it possible to view the current value of the "when marked inactive" custom attribute somewhere in the gui? Thanks Regards, Thorsten
asked Jul 6, 2012 by techman26 (240 points)
asked Mar 21 by EdgarsABG (50 points)
Hello! Is there a way to clear the AD attribute "thumbnailPhoto" with a checkbox property? I wanted to implement a checkbox in the mask "Modify user" and if the box is checked, clear the attribute. How do I implement this? Much appreciated, Marco
asked Apr 21, 2022 by marco_jandl (60 points)
3,351 questions
545,079 users
