Hello
We are using the script you created for us to upload the employees photo based on their employee ID which works fantastic. The script is below:
$picturePath = "picture path"  # TODO: modify me
# Check whether a file with the photo exists
if(!(Test-Path -Path $picturePath))
    $Context.LogMessage("The path to the user's picture is incorect.", "Error") # TODO: modify me
# Save picture to AD
[Byte[]]$pictureInByte = Get-Content $picturePath -Encoding Byte
$Context.TargetObject.Put("thumbnailPhoto", $pictureInByte)
As we only want to add a photo if there is not one at the moment and then add the user to a group we currently use it in a custom command that has the following actions:
If the 'thumbnailPhoto' property is empty then
Run PowerShell script 'Import Photo' for the user
Add the User to the 'AD Group Name' group
We have run into issues recently where the user does not have a photo loaded but there in not a photo in the location to load, we get the error message but they way we have it the user is still added to the 'AD Group Name'. We would like to amend this so if there is no photo loaded they are not added to the group. If there is a photo uploaded they would still be added to the group.
Could you help out please? I feel like I am missing something obvious but can't see how to do it :?
Thank you.
by (700 points)
In this scenario, it is better to add users to the group directly in the script. Here's a version of the script that will do the job. In the script, $groupDN specifies the Distinguished Name (DN) of the group a user must be added to if the picture has been imported correctly.
$picturePath = "\\SERVER\Share\%username%.jpg" # TODO: modify me
$groupDN = "CN=Import Photo,CN=Users,DC=example,DC=com" # TODO: modify me
# Add the user to the group
Thank you this works perfectly.
I would like to add a parameter for country to a custom command. Since the country has to be entered correctly in order for Active Directory to accept it, I would like to ... ? I didn't find it in the documentation and the sample scripts didn't use parameters.
asked Jun 4, 2020 by mark.it.admin (2.3k points)
As the title says, Im looking to add a Custom Command to the Action pane that I plan to allow users to trigger a script to run. However when in the Web Config for ... as has the permissions to make changes to the Web Inferface. Am I missing something? Thanks
asked Jul 16, 2019 by Helios5287 (100 points)
3,365 questions
545,265 users
