How are people going about configuring employees transferring or being promoted?
Right now our HR is responsible for submitting the user creation forms, which in return kick off our user creation templates based off a drop down in the description field. This drop down in the description changes via property pattern based off which department OU they select when creating the user.
My question is, how can we best go about setting it up so HR can easily select an employee, select the new description, and have it remove all groups and add the new position groups?
by (520 points)
You can use Business Rules for this purpose, the same as you do on account creation, but in this case the rules need to be triggered when updating a user. For a description on how to achieve what you want, see section Update Membership by Schedule, on Creation and Modification in the following tutorial: http://www.adaxes.com/tutorials_Automat ... y_schedule. This is the recommended approach for your situation.
However, if you have many options for the descriptions, maybe it would be easier to use a PowerShell script instead of multiple actions/conditions as recommended in the above tutorial. For a script sample, see the following tutorial: http://www.adaxes.com/tutorials_Automat ... cripts.htm. You need Example 1.
Hello. We need Adaxes to run a script every night that strips leading zeroes off of employee ID. Or better yet (each time the employee ID is set or changed?) Example: Tech puts ... ID. It will strip it down to 556 Would powershell be the way to do this? Thanks
asked Dec 20, 2021 by silicondt (60 points)
Working within a DoD environment all interactive user accounts are required to have an @mil suffix. Within the application though I am unable to make the required change to anything ... environment? The employee types consist of CTR, SVR, WKS, ADMIN, and APP.
asked May 13, 2019 by jason.d.jones (100 points)
Hi Is it possible after creating a user, run a script in the background that generates the next Employee ID, assign it to the user then email it to interested parties? If not, ... ID with some kind of check, that makes sure it is not being used? Cheers D
asked Feb 15, 2016 by DFirmin (20 points)
All of full time employees have an employee ID, the issue I have is trying to display the employee ID field in a web portal page. I have both the employee ID and ... have a value displayed in the employee ID field. your assistance would be very helpful. Tony
asked Jul 15, 2015 by babbeaw (320 points)
Hello, is there a way when creating a new user and selecting their manager to only display ad objects w ith a certain property? We are looking at using ... contractors into different OU's and only make the staff OU available when selecting managers?
asked Sep 26, 2012 by chriswharton22 (60 points)
3,351 questions
545,077 users
