Trying to read data from as SQL database and .ExecuteReader() appears to be successful, but while .Read() must be returning False. Please review the code below and explain what might be wrong. Thanks
Here is my code:
Import-Module Adaxes
$databaseHost = "[i]dbHostname[/i]"
$databaseName = "[i]dbName[/i]"
$tableName = "[i]tableName[/i]"
$userIDField = "EMPID"
$databaseUsername = $NULL
$databasePassword = $NULL
# Connect to the database
$connectionString = "Data Source=$databaseHost; Initial Catalog=$databaseName;"
if ($databaseUsername -eq $NULL)
    $connectionString = $connectionString + "Integrated Security=SSPI;"
        "User ID=$databaseUsername;Password=$databasePassword;"
    $connection = New-Object "System.Data.SqlClient.SqlConnection"  $connectionString
    $connection.Open()
    # Check whether the user exists in the database
        $command = $connection.CreateCommand()
        $command.CommandText = "SELECT EMPID, LASTNAME, FIRSTNAME FROM $tableName WHERE $tableName`.$userIDField = @UserID"
     #   $command.Parameters.Add("@UserID", "%employeeID%") | Out-Null;
        $command.Parameters.Add("@UserID", "500333") | Out-Null;
        $Context.LogMessage($command.CommandText, "Information")
        $reader = $command.ExecuteReader()
        # Close the search and release resources
        $command.Dispose()
    if ($reader -eq $NULL)
        $Context.LogMessage("A user with employee ID " + "%employeeID%" + " does not exist in the database", "Warning")
        return # Exit script
    {   $Context.LogMessage("before While", "Information")
       while ($reader.Read()){
           $Context.LogMessage("inside while loop reading records", "Information")
        $empID=$reader.GetString(0)
        $lName=$reader.GetString(1)
        $fName=$reader.GetString(2)
       # $deptNum = $reader.GetString(3)
       $Context.LogMessage( $fName,"Information")
catch [System.Exception]
    $ErrorMessage = $_.Exception.Message
    [string]$LineNumber = $_.InvocationInfo.ScriptLineNumber
    [string]$Offset = $_.InvocationInfo.OffsetInLine
    [string]$errLine = $_.InvocationInfo.Line
    Write-Error $ErrorMessage
    $Context.LogMessage("At Line #: " + $LineNumber + " at char " + $Offset, "Error")
    $Context.LogMessage("Executing: " + $errLine, "Error")
        # Close the database connection and release resources
        $command.Dispose()
    $connection.Close()
by (270 points)
The thing is that an instance of the SqlDataReader class represented by the $reader variable exposes the MoveNext iterator. It is used to enumerate the records returned by the database. When you call the $reader variable on this line:
this forces PowerShell to enumerate all members of the $reader SqlDataReader class (i.e. properties, methods). When doing so, it also enumerates all records returned by the database and moves the MoveNext iterator to the very last line returned by the database. When you further call the $reader.Read() method, it also tries to call MoveNext, but since it is already the last record, there is nowhere to move further. This is where the error occurs.
Here's an updated script that resolves the issue:
    $connection.Open()
    if ($reader.Read())
    if ($reader) { $reader.Close() }
    if ($command) { $command.Dispose() }
    if ($connection) { $connection.Close() }
Is it possible to query the external SQL database for audits of a specific action, even if that action is a 'sub-command' of a business rule, scheduled task etc? Simple ... interested if data is structured in the log in a manner that would allow this? Thanks
asked Aug 30, 2014 by firegoblin (1.6k points)
We have a need to restore and read audit logs from a backup. We have restored the backup but are looking for guidance on the easiest method to access logs within this file. Thanks in advance!
asked Nov 22, 2016 by VTPatsFan (610 points)
Hi, Is there a simple way to read the Exchange AD attributes without having to use the custom Exchange ADSI interface API? I'm trying to write an Adaxes Scheduled Task ... Limit") - other than the fact that the command doesn't recognise the property! Thanks
asked Aug 19, 2015 by firegoblin (1.6k points)
Short question: I have a Powershell script that is generating some information and saving it to a SQL table. Is there some way to save that information into a field in AD ... using Adaxes, but I don't know how to go the opposite way basically. Thanks!
asked Mar 12 by cstaub (50 points)
3,350 questions
545,068 users
