Hello @All,
I use external logging in MSSQL and now we have 29GB database size and i want to cleanup the logs older that 6 month.
The biggest tables are:
a) Operations
b) Operations2OperationTypes
What can I do to cleanup the entries in the db?
Thanks ;)
Arne Tiedemann
by (360 points)
Hello Arne,
To cleanup events older than 6 months, execute the following command on your SQL Server:
DELETE FROM [AdaxesLogDB].[dbo].[Operations] WHERE [OperationStartTime] < DATEADD(month, -6, GETDATE())
where AdaxesLogDB is the name of the logging database.
Hello again, I am planning the upgrade to 2013.2, but I would like to do it to a new server. The documentation is about using the same server (http://www.adaxes.com ... would like to have the current one migrated (SQL Settings). Thank you very much in advance
asked Nov 25, 2013 by Pierre (750 points)
If a user is disabled, I would like the following process to be automated: Direct reports of this disabled user (user A) are reassigned to new active user (user B) who ... is sent to User B indicating User As direct reports have been transferred to User B
asked Apr 29, 2022 by Cavolick (60 points)
Hello, Where i'm actually working, it seems there is an "old dev" Adaxes environnement which was linked to the AD. The server has been deleted now, but it seems the Windows ... Even if i install a fresh client. Where those parameters came from a GPO i guess ?
asked Apr 26, 2016 by Alexandre (460 points)
Another question :roll: When updating a user account, in case of username's change, I would like to run a script with variables like the old username value and the new one. I do not see how to call the old value. Is it possible? Thank's in advance, Yoann
asked Aug 22, 2012 by yoann.hamon (180 points)
3,350 questions
545,074 users
