Hi
In the Management Console we have our Custom Commands in folders to make them easier to find.
How would we replicate this in the Web Console page? The Custom Commands available to the user just appear as a long list under the 'Other' menu. Of course this means the ones we use most frequently are at the bottom... At the least we would like to have this list appear in alphabetical order, we could work with this by standardising our Custom Command names, but what would be even better if the list could be the same as what we have in the Management Console and be sorted neatly in folders.
Thanks in advance :)
by (700 points)
In our sandbox, we have a request to organize Custom Commands in sub-menus the same as they are organized in containers. We'll consider this request when deciding on features for future releases. For now, you can do the following to improve the situation:
  • Hide unnecessary Custom Commands
    If you have certain commands that cannot be executed manually and executed exclusively for Business Rules, Custom Commands and Scheduled Tasks, you can disable them. Disabled Custom Commands are not shown in the Web Interface or in the context menu for AD objects in the Administration Console, but can be executed by Business Rules, Scheduled Tasks and other Custom Commands. How to disable a Custom Command.
  • Organize Custom Commads
    If you have certain Custom Commands that you use much more often than the others, you can make such commands available directly on the object view so that you can use them without the need to open the Other submenu.
    For more details, have a look at step 8 of the following tutorial: http://www.adaxes.com/tutorials_WebInte ... bjects.htm.
As you can see in the picture, we currently have three different formats as soon as we look at a user's data. Can this be adjusted so that only one format dd.mm.yyyy is displayed? Thank you very much
asked Nov 17, 2023 by DRiVSSi (280 points)
Hi Is it possible to get the Web Interface address via a script? Thanks Matt
asked Oct 13, 2023 by chappers77 (2.0k points)
Hi I have create a business unit located in Business Units --Test BU's ----FTE Accounts Then I have created a Security Role called Test User Management with me as ... shown at all. I have the headline business units but nothing in there. Thanks Peter Sonander
asked Feb 7, 2023 by Sonander (40 points)
asked Jul 7, 2022 by Vish539 (310 points)
3,351 questions
545,081 users
