I've adapted a RegEx to normalize phone numbers, source: http://www.regexplanet.com/cookbook/pho ... index.html.
Import-Module Adaxes
$identity = "%sAMAccountName%"
$mobileNumber = '%mobile%' -ireplace '\D*([2-9]\d{2})(\D*)([2-9]\d{2})(\D*)(\d{4})\D*', '+1 ($1) $3-$5'
Set-AdmUser -Identity $identity -MobilePhone "$mobileNumber"
Testing in the Powershell IDE works perfectly on all phone numbers I gave it. However, when running on numbers formatted at +1 (888) 555-5555, adaxes returned +1+1 (888) 555-5555.
Any guidance on this?
by (1.2k points)
I fixed the problem by escaping the input with:
see below.
Spoke before I actually tested in adaxes...
The function works once you move the escape to the input as follows:
$mobileNumber = \[Regex\]::Escape('%mobile%') -ireplace '\\D\*(\[2-9\]\\d{2})(\\D\*)(\[2-9\]\\d{2})(\\D\*)(\\d{4})\\D\*', '+1 ($1) $3-$5'
If anyone has any suggestions on improving efficiencies, please post.
The thing is that \D* (non-digits) doesn't include a sequence of characters that contain a plus (+) sign. So, to resolve your issue, you simply need to replace the starting and ending \D* with .* (matches any character). In this case, your zero-level character class will include all characters in the string. The resulting regular expression is as follows:
.*([2-9]\d{2})(\D*)([2-9]\d{2})(\D*)(\d{4}).*
In this case, you don't need to escape anything, just call -ireplace on the value returned by %mobile%:
$mobileNumber = '%mobile%' -ireplace '.*([2-9]\d{2})(\D*)([2-9]\d{2})(\D*)(\d{4}).*', '+1 ($1) $3-$5'
Hello I'm trying to run a custom PowerShell script to request a Workspace ONE Access Sync when I change something in our users or groups. Here is the script: $ClientId = "api ... of having to create 6 independent rules with each of them a copy of the script)?
asked Sep 25, 2021 by ygini (240 points)
We have an inactive user task which runs daily that disables accounts after 30 days of inactivity. We had an example yesterday of a user account which had been disabled ... Are you able to provide any explanation of how this could have happened? Regards Andy
asked Sep 12, 2017 by Andy_W (40 points)
I am trying to use this script from the script repository: https://www.adaxes.com/script-repository/enable-mfa-with-phone-number-for-a-user-in-microsoft-365-s686.htm I ... if I just didn't install it correctly because Adaxes Powershell doesn't recognize it.
asked Oct 10, 2023 by ocanizales (40 points)
3,350 questions
545,068 users
