Hello Support
We are looking to integrate Adaxes with the HR SQL data warehouse. We found the http://www.adaxes.com/script-repository ... e-s249.htm and have some questions as to how it will work.
Our thoughts are that we will have the SQL database compare yesterday's SQL table to today's and that way we only make changes to the accounts that have changed instead of having to "touch" every account. Please let us know if this is acceptable and recommended method.
We are thinking that we will drive the creation, modification and deprovision of accounts all during the same time. Is this the recommended process? This way we believe we can run it once during the night and make all changes at once.
Thank you
for all your continued support
Jay
by (3.2k points)
Hello Jay,
It is an acceptable approach and can be achieved using PowerShell scripts.
We recommend separating the processes as it can take long time to execute the script.
Our SQL DBAs are working to move most/all our SQL connections to SSL. They have asked if Adaxes can support this.
asked Feb 22, 2021 by ggallaway (300 points)
Dear Adaxes team, Please confirm if Adaxes 2019.1 support SQL server 2017 for logging database. Also suggest Adaxes steps to perform if we are migrating our logging database from SQL server 2012 to SQL server 2017
asked Apr 16, 2020 by kushal.gaurav (20 points)
We have a client that is using another product for tracking change history and Active Directory auditing. Does Adaxes provide such tracking for Active Directory objects, passwords, etc. ?
asked 1 day ago by daviddickerson (20 points)
Hi All, I am looking for a script i can use in adaxes, that removes all delegates for an exchange O365 mailbox, and reset their MFA tokens as well. I ... ($mailbox.Identity)" } } } # Disconnect from Exchange Online Disconnect-ExchangeOnline -Confirm:$false
asked Apr 18 by Brobertson92594 (20 points)
3,362 questions
7,812 comments
545,229 users
