We have an hybrid situation and the mailbox should be create in Exchange onPrem. And if we create a new user, we copy another user with groups. The question is, how can i remove ... of groups from user are the last part of the prozess. Do you have any ideas?
answered 16 hours ago by Support3 (16.7k points)
I'm building out our user offboarding for HR. Is it possible to have a field in the webform for disabling a user account where they can enter in a ticket number? ... business rules but we need to get the term ticket number into this process for record keeping
answered 18 hours ago by Support2 (310k points)
Hi, can Adaxes support NoSQL as database for logging? Are there any plans to support other types of databases in future?
answered 2 days ago by Support3 (16.7k points)
Hi team, is this still not possible? Even with a security role to deny write access to a certain attribute/field?
answered Jul 14 by Support2 (310k points)
Hi, In our previous Adaxes Web Interface version (2023), we used to pre-fill the username field on the Sign-in page via URL query string, e.g.: https://.../ ... Is there any supported alternative to pre-fill or bypass the username step on Sign-in? Thanks!
answered Jul 9 by Support2 (310k points)
Hi team, Is there any possibility, or a planned feature, for better logging control? I would like to show only relevant, useful information in the execution log visible in the portal, but write more detailed/verbose logging into the database itself.
answered Jul 1 by Support3 (16.7k points)
We recently received some pentest results that flagged the password reset workflow as being vulnerable to user enumeration. When a user attempts to reset a password we get ... your email" and require that link to access the security questions/reset workflow?
answered Jun 29 by Support2 (310k points)
We are moving away from on-prem in the near future and are wondering if it's possible to install Adaxes on an Azure VM to manage EntraID users + exchange? We are not looking to manage devices.
answered Jun 26 by Support2 (310k points)
Is it poossibel to run pre and post commands before processing all objects, and then after processing all objects? I have a process that validates if a user account should be ... to be able to tell if the process failing is causing mass disabling of accounts.
answered Jun 19 by Support2 (310k points)
I'm setting up e-mail notifications when a group is created or deleted through Adaxes. One thing I'd like to include is what type of group is being created (Distribution, M365, ... I can use? Or do I need to go the Powershell route instead of just using email?
answered Jun 16 by Support2 (310k points)
Is it possible to have those account options added to Adaxes to support AES in the case of the RC4 depreciation in business rules? Like After Creation, ... modify account options... or define them by default in the Properties?
answered Jun 11 by Support2 (310k points)
Is it possible to view Entra Extesions Properties via Adaxes. For example in this article it shows how to add a new property to specify what groups shoudl ... .microsoft.com/en-us/entra/identity/hybrid/cloud-sync/tutorial-directory-extension-group-provisioning
answered Jun 10 by Support2 (310k points)
I am looking for a way to adjust how properties are expressed, without creating a custom attribute. For example, the attribute "Lockout-Time" is shown as "enspecified" if ... I was wondering if I could change it without creating a custom attribute. Thank you!
answered Jun 5 by Support2 (310k points)
No edit button is available within Adaxes for these accounts. The service account has 'Mail Recipients' and 'MailRecipientCreation' permissions assigned. What additional configuration or permissions might be needed?
answered Jun 2 by Support2 (310k points)
Hi team, We are running version 2025.1 - 3.17.23904.0 with three servers and one SQL server. Two of the three servers are used for web access behind a load ... issues if we revert to the previous version (internal database/settings and SQL logging database)?
answered Jun 1 by Support2 (310k points)
I have a custom adaxes attribute that I would like to utlitize in Rule Based groups; it does not look like they are available to select, however. Example: want something ... to group. Is this possible to make them visable in the Rule Based queries somehow?
answered May 28 by Support2 (310k points)
I am introducing Adaxes to more of my IT team ... and this includes those who are in DevOps and want to put everything in a Git repo. I'm not an expert on this ... but I've always managed my scripts manually - keeping copies locally in my file system. Thanks.
Hi, from where gets Adaxes the list of values prefilled, especially for the Country attribute? I noticed there is a value of "CS" which is not supported on Active Directory. Thanks.
answered May 27 by Support3 (16.7k points)
We are using Adaxes Directory Object Picker for selecting Distribution Group members. We create external recipients as Exchange Online MailContacts (via New-MailContact). These contacts: are ... Context: We are using cloud-only contacts (no on-prem AD sync).
answered May 27 by Support2 (310k points)
To see more, click for the full list of questions.
