What ports does Adaxes use?
FAQ section
Postby Support » Thu Nov 18, 2010 2:51 am
Adaxes Service
To enable communication between Adaxes service and Active Directory, the following ports (TCP and UDP) must be open for outgoing connections on the computer where your Adaxes service is installed, and for incoming connections on the Domain Controller(s) that you want Adaxes to connect to.
  • 389 LDAP - to connect to Active Directory
  • 636 LDAP (SSL) - to connect to Active Directory via SSL
  • 3268 GC - to connect to AD Global Catalog
  • 88 Kerberos - for authentication
  • 135 RPC - to resolve AD user names
  • Dynamic RPC ports* - to communicate with Active Directory
Additionally, to allow communication between Adaxes service and your Exchange Servers, you need to open the following ports:
  • 80 HTTP - if Adaxes service and Exchange are installed in the same forest
  • 443 HTTPS - if Adaxes service and Exchange are installed in different forests
Also, you need to allow Adaxes service to ping Active Directory domain controllers. To do this, enable Echo ICMP Requests (ping) in the firewall settings.
Adaxes Clients
Adaxes Web Interface and Adaxes Administration Console use the following ports (TCP and UDP):
  • 54782 - for communication with the Adaxes service
It is possible to change the port used for communication between Adaxes service and Adaxes clients (Web Interface and Administration console). For this purpose you need to change the port attribute of the following XML element of the Adaxes service configuration file (Softerra.Adaxes.Service.exe.Config):
Code: Select all
<configuration>
    <system.runtime.remoting>
    <customErrors mode="Off" />
    <application>
      <channels>
        <channel ref="tcp" port="54782" priority="2" secure="true">
The Softerra.Adaxes.Service.exe.Config file is located in the folder where the Adaxes Service is installed (by default, C:\Program Files\Softerra\Adaxes 3\Service).
* To enable communication through dynamic RPC ports:
Active Directory Identity Management
Follow Adaxes in social networks
Image Image Image Image
User avatar
Support
Site Admin
Return to FAQ [read only]
Who is online
Users browsing this forum: No registered users and 0 guests
