Is it possible to leave the "User must change password at next logon" checkbox unchecked by default?
I see options to set the other properties but not this one.
by (50 points)
Yes, it is possible. For information on how to set default Account Options for new users, have a look at the following tutorial: https://www.adaxes.com/tutorials_Simpli ... gUsers.htm.
Is it possible to leave the "User must change password at next logon" checkbox unchecked by default? I see options to set the other properties but not this one.
asked Jan 8, 2014 by sdavidson (730 points)
How do I set the Account Controls via pattern or business rule to cause new user accounts to be set to force a password change at their first logon. Thanks!
asked Jun 4, 2012 by mpaul (360 points)
User received email from Lumifi and wanted to verify if legit or if this is not from Adaxes?
asked Nov 30, 2022 by Jeff.Briand (60 points)
Is it possible to trigger an external API request to update another directory whenever an AD user changes his password? Even if the password change didn't occur using adaxes, but directly in Active Directory? Thank you.
asked May 29, 2020 by nicolasdsa (20 points)
Hello again! I discovered to make the password reset function with default account options (force password reset on first logon checked, User Cannot Change Password and password never expired ... that I can add to my script, I just can't find the darn thing.
asked Nov 20, 2015 by drew.tittle (810 points)
3,350 questions
545,074 users
