we have a problem when calling the Exchange properties. This takes a very long time. Can we speed up in any way? How then does the communication with the Exchange?
Thanks a lot and greets,
Dennis
by (40 points)
Hello Dennis,
Adaxes communicates with Exchange Servers using Exchange management cmdlets and PowerShell remoting. To troubleshoot the issue with slow loading of Exchange properties, you can:
  1. Enable tracing of commands sent to your Exchange Server. How to Trace Requests to Exchange Servers.
  2. In the generated trace file, you will find the name of the Exchange Server that Adaxes communicates with.
  3. Check whether communication between the computer where Adaxes is installed and the Exchange Server it communicates with is not hindered by any conditions. For example, Adaxes can communicate with an Exchange Server located in another AD site.
By the way, what version of Exchange are you using?
by (40 points)
thank´s for the quick reply. We´re using Exchange 2013 CU3.
Greets, Dennis
Hello Dennis,
Did you try enabling tracing of commands sent to Exchange Servers? Are the computer where Adaxes is installed and the Exchange Server it connects to located in the same AD site?
by (40 points)
Computers are in the same AD site. The Command "Get-ADPermission" takes about 40 seconds :roll: Mh.... sooo many entries (?)
Greets, Dennis
Dennis,
Can you send the trace file to our support e-mail (support[at]adaxes.com)?
by (40 points)
sure... Mail was send...
Greets, Dennis
Dennis,
The issue really seems to be in Get-ADPermission. It is the only cmdlet that takes so much time to execute.
The thing is that the Get-ADPermission cmdlet gets permissions for the mailbox. Each user that has certain permissions for the mailbox is stored in the form of a Security Identifier (SID). The Get-ADPermission cmdlet translates the SIDs into names of the users/groups that have the permissions. This can take some time in certain situations.
To troubleshoot the issue, can you do the following:
  1. Logon to the Exchange Server that is mentioned in the trace file.
  2. Launch Exchange Management Shell (EMS).
  3. Execute the Get-ADPermission cmdlet exactly as it is shown in the trace file, piping the output to a CSV file. For example:
     Get-ADPermission -Identity "CN=User,CN=Users,DC=example,DC=com" -DomainController "server.example.com" | Export-CSV C:\Export.csv
    where C:\Export.csv is the full path to the CSV file that will be created.
  4. Send the generated CSV file to us.
by (40 points)
ok... Mail was send...
Greets, Dennis
Hello, I am trying to do as best as I can researching the best and effective way to manage the properties of Office 365 Exchange Properties with Adaxes (Latest Version) ... sure if there is a command or config I missed for adjusting the Distribution Lists.
asked Dec 19, 2023 by Edogstraus00 (590 points)
I am using an account with global admin permissions to o365, so it does not appear to be that as the issue. Adaxes V.2017.2 Trace logs showing the following [11/02/2022 11:24:58] ... at #2e.#Vh.#h8() at #eb.#Wb.#j8() at #2e.#Uh.Execute(#ib command) Any ideas?
asked Nov 2, 2022 by bbrunning (50 points)
Hi, In our system we a hybrid domain with Office365, so on prem AD accounts, O365 mailboxes with an OnPrem exchange for some legacy mailboxes. We have a number of AD accounts ... it's an option in a newer version that's absolutely fine as well. Thanks Gary
asked Feb 27, 2020 by gazoco (490 points)
Receive the following error when trying to access our Exchange properties. "Could not load file or assembly 'System.Management.Automation, Version=3.0.0.0, Culture=neutral, ... recently, and I'm not sure where to begin searching for a solution. Regards.
asked Oct 22, 2018 by jtop (720 points)
