If I buy 2026.1 today without AMS, is there any support/major updates included for a limited time, i.e. some sort of free AMS for 30 days after the purchase?
Similarly, are subsequent minor updates included if you buy without AMS? i.e. you bought 2026.1 in Jan. 2026, can I install Update 4, 6 months later? Or do you have to maintain AMS even for minor updates?
Can you also buy AMS at a later date (assuming you're on the current version)?
Thanks, TJ
by (17.0k points)
Yes, when purchasing a license without AMS, you have 30 days of free AMS. It means that if a new major version of Adaxes is released during these 30 days, your license will allow you to use the new Adaxes version.
Minor updates do not require AMS. If you purchase, for example, a license for Adaxes 2026.1, all minor updates for the version will be available to you no matter when they are released.
Yes, you can purchase AMS later if the version you are currently using is the latest one.
Hi, I am trying to clear the manager of disabled accounts and created a scheduled task for this Right now it is failing for all users (currently 4 in total) With error ... but it won't also remove/clear the manager. All user still have the attribute set.
asked Jan 30, 2024 by wintec01 (2.7k points)
Hello! As part of my onboarding routine, I have a custom form that has a Boolean value for send welcome email to employee. I also have an optional field for personal ... ? If not is the best method using a business rule check before creating the user?
asked Aug 17, 2023 by thatcher (220 points)
What permissions are required, other than Domain Admin, to edit the Adaxes configuration (business rules, property patterns, custom commands, etc.) in the console and the edit the web portal configurations in the AdaxesConfig web site?
asked Dec 6, 2019 by RickWaukCo (320 points)
Hello, I got a clear request from our Service Desk "for all modifing actions" we need a ticket number. That means I'm looking for a way to pop-up a small screen to ask for the ... ... But until now - I was not able to find a solution. :cry: Many thanks, Horst
asked Jul 4, 2018 by HorstR (460 points)
We're looking at enabling the Lync support in Adaxes, but current it cannot find the pool\registrar servers etc. I assume this is related to missing privileges (we don't run with Domain Admin rights); do you have a list of the minimum rights required? Thanks
asked Jan 10, 2014 by firegoblin (1.6k points)
