When trying to modify a user via web inerface, logged in as administrator, after selectin user, clicking on it i receive the following error:
Fatal Error
Length cannot be less than zero. Parameter name: length.
Can you help me?
Thanks,
Claudio
Hello Claudio,
Please have a look at the Adaxes Event Log. See this help article on how to view the log: Service Event Log
Are there any errors or warnings related to the issue?
this is the error reported:
Softerra.Adaxes.Web.Common.FatalErrorException: An unhandled exception occured (for details, see messages below). ---> System.ArgumentOutOfRangeException: Length cannot be less than zero.
at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
at Softerra.Adaxes.Web.UI.ManageDirectory.Controls.LogonHoursEditor.CreateColumnHeaderCell(Int32 columnIndex, String timeSeparator)
at Softerra.Adaxes.Web.UI.ManageDirectory.Controls.LogonHoursEditor.CreateLogonHoursTable(TableCell cell)
at Softerra.Adaxes.Web.UI.ManageDirectory.Controls.LogonHoursEditor.CreateChildControls()
at System.Web.UI.Control.EnsureChildControls()
at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Hello Claudio,
What locale settings are you using in the web browser that you are trying to open the Adaxes Web Interface from?
As a workaround, you can change the locale to English (United States) (en-us). Another option is to remove the logon hours property from the form if you don't need it. See step 6 of this tutorial on how to accomplish this: Customize Forms for User Creation and Editing.
However, if this issue is critical for you and you cannot use any of the workarounds, we can make a custom build.
I am looking for a way to ensure that a custom command can only be run is an user account is more than 30 minute old. Ideally I would like the command to be hidden ... is less than 30 minutes old. We need this check because of sync timings. Thanks, Allistair
asked Dec 18, 2023 by a.blonk (190 points)
Error occurs when trying to use SSPR from self-service web interface and from the Windows login screen. Has anyone seen this before? I haven't been able to ... configured exactly how it is laid out here: https://adaxes.com/help/ConfigurePasswordSelfService/
asked Apr 19, 2023 by dhodgin (80 points)
The Adaxes web server running on IIS recently stopped working after a reboot. Nothing has changed, it was a routine restart no updates were installed, After the web server ... but from any web interface, it shows this error. Any help would be appreciated.
asked Nov 25, 2024 by ADuser (60 points)
Upgraded to the latest adaxes release yesterday and now this morning we are not able to access our self-service portal. We have rebooted our server and verified our adaxes service is successfully connected our domains. Any help would be appreciated, thank you!
asked Mar 14, 2024 by dhodgin (80 points)
Hello, I get this error after logging into the web interface (As Adaxes Admin):   Fatal Error - Cannot process the request because the request signature is invalid or ... Adaxes Services/Server about 3 or 4 times now and restarting the computer as well.
asked Feb 6, 2023 by Edogstraus00 (570 points)
3,683 questions
8,518 comments
549,505 users
