by (410 points)
You need to make sure that the web interface is configured accordingly. For example, it can be currently set to only display objects located in a specific AD domain. The following tutorial will be helpful: https://www.adaxes.com/help/ControlObjectsDisplayedInWebInterface.
Also, make sure to grant users the required permissions to see the objects in the Microsoft Entra domain: https://www.adaxes.com/help/HideObjectsFromUsers.
by (410 points)
Can confirm the permissions are set to view all objects. My account is a service administrator so I have access to all objects and domains.
What about the web interface settings? Did you check them according to the tutorial we referenced in the previous post?
asked May 15, 2024 by tromanko (410 points)
asked Mar 20, 2024 by tromanko (410 points)
I would like to show a couple of Adaxes Virtual Attributes in the Web Portal. I've added them in the Configuration, see the 1st screenshot below. I've ... . Any help? Virtual Attributes added Security Role has permissions Virtual Attributes not showing up
asked Jul 29, 2020 by nate2 (90 points)
I created an entry in the AttributeFriendlyNames2.eng.xml file, but the real name still shows instead of the friendly name in both the Web Console as well as the Adaxes ... Others, like this one seem to work fine: Fen-UM-Coversheet FAX Coversheet Any ideas?
asked Jan 5, 2017 by Kikaida (1.1k points)
